schiker
Uhhhgg dang it. %$#*@%$!!!! that ding dang heater hose quick disconnect fitting.
Well, it defeated me. I bought one of the tools you hammer into the broken fitting like a straight easy out. It did not work I did not hammer in far enough. So then I tried Robyn's trick and cut it 2 plcs with a dremel then hammered the tool back in and proceeded to strip it out and generally boogered it up. Must not have cut deep enough or my fitting was just that corroded into the aluminum.
It broke off just touching it trying to unhook the plastic keepers for the metal hose end. It was pitted in the break and generally corroded in half. Man that stuff is some crappy metal. Probably find out later it will cause cancer.
So I am admitting defeat and ordering a new cross over.
Will the NPT fitting to hose adapter for the water pump hose the one that goes down besides the oil fill spout come with the new cross over? Or is that extra?
I might try and take that out of the old one before tossing it but right now I am going to enjoy a beverage before looking at that ding dang thing again.
