ak diesel driver
6.5 driver
Paperclip works good to slide in from the backside and under the silicone seal
Also ohm extension harness and repeat the same test you just did at the end on the extension harnessWill retest red wire and ohm grounds. First test was to pmd
Best place to start.That test was at the end of the extension harness.
When I had the pump removed from My truck, after bleeding the low pressure side, cracked fuel lines at all the injectors I could easily get to, then cranked for maybe a minute and fuel than began to pulse from the fittings, tightened the lines back up and it took right off. Missed for a little while but when the other injectors got fuel it smoothed right out.How long does it take to purge air from system after pump swap?
Did the testing all wires check out except 984 light green. I get 28-30 mv with key off. 4.9v with key on engine off. Crank .5-.6vThis should give you enough info to make sure the pmd is getting the signals it should as well as the output
