btfarm
America First!
I think I'd leave it then as long as your side to side is even. Likely it was cranked some when you bought it.
Cranking the torsion bars is not bad but you can go to far so make sure after you adjust you make sure you maintain at least 5/8"s between the UCA and frame stop. This is seen in the pic below
Also like Nick/Unit453 suggested a new upgraded shock will help the most because now you have changed the over all ride height pre-load and reduced the down travel at ride height so the OE shock is very loose in valving and even if you fix the length in lower mount or extension the truck will reach the full drop out fast and abrupt, harsh ride. A new shock, I really like the Bilsteins over the rest will provide a better valving while fixing the over all length and be the better bang for the buck.
Truck looks great by the way!!!:thumbsup:
yeah, I did that both driving forwards and in reverse. It clears now but not by a whole lot. I trimmed the valance and front fender well plastic a little. What worries me is what happens when I pack those tires full of mud? That's why I'm thinking I need to crank those bars a tad more.
thanks....I had seen that info a time or two and the upper measurement is kinda confusing to me. Do I measure from the top (frame side) of that frame stop or the bottom ( outboard side) of that stop? Right now there's still quite a bit of room even measuring from the closest point. The lower bump stops though already look ~1/4" just by eyeballing it. I'm gonna go up a little more I think tonight and I'll make sure to measure those points.
That Nick sure knows his business!:thumbsup:
