3 full turns gave me 1".....does that sound about right?
I put a level on the frame and it's balls on front to back both sides...is that the proper way to check the truck for level?
Looks like I'm off a little less than 5/16" side to side (drivers side is higher). Big deal? Doesn't bother me one bit and I figure once I'm in the drivers seat I can take up some of that difference. Should I worry about that 1/4"ish?
I'm not wanting to go any higher than I have to.....I'll trim the valance if I need to for the new wheels. I know you guys aren't magic genie's and I'll find out soon enough but a 285 tire on a 16x8 with zero offset...am I gonna have trouble fitting these with just 1" of lift? I'm trying not to crank them any further than I have to because eventually (hopefully this winter or early spring) I'll be going with a lift so for right now I just need to fit the tires.
I realize these questions have been beat to death all over the web but it's nice to have some fresh or new points of view on things from time to time.
