ak diesel driver
6.5 driver
wouldn't that hydrolock the IP?
Ok thanks, thats why I asked, don't want to explode anything!!! So if I do leakdown 100 psi at tdc of the low cylinders on compression strome and don't hear any air coming from the dip sick or lower end its probably just heads or gaskets? Thanks MikeWet compression test turns the oil you are using into fuel and the cylinder ignites blowing compression gauge up like hand grenade. You have to be able to do it with liquid that cant combust if doing wet comp test.
Otherwise, do leak down (100psi is how I learned it) dry and wet- very rarely you can tell the rings/walls are bad that way but worth trying if unsure.
Blocking off injection line and running engine is like unplugging spark plug wire and injector on a gas engine. It will fight the other cylinders and not just loose power from itself not working but make the other cylinders work harder. Your turning the v8 into v7 with power of v5. It is taking life out of the engine faster. Not a great long term option but sometimes ya do what ya gotta do. But if soon to be rebuilt/ replaced anyways...
I cant remember if i have ever done it to one of these pumps, but I have similar ones that use pop injectors with no problem. True, better to not risk it and run a dedicated return line back to the tank if needed.wouldn't that hydrolock the IP?
