dieselsmoken33
I'm looking in getting a cooling up grade for my 93 6.5. Would it be better just to go with the SSDS kit or replacing the stock radiator with a 4 row monster.
What is coil cleaner and where would you buy it? Would foaming engine cleaner work? I'm doing a cooling system upgrade on my 95 2600LD in my sig. Ive added the 97 HO water pump and plan on using the fan/clutch from a 3500hd[more blades]. I also removed the a/c condensor{didn't work anyhow]. I'm using the rad out of a 97 2500 and want it as clean as possible before installing. And yes I put a genuine Ac delco[13191] thermost in.
I am having issues with overheating while towing even moderate loads. I have a new radiator and have cleaned the system. Even though my truck is a mostly a daily driver I need it to tow heavy loads from time to time (7,000-9,000). I am interested in either the Kennedy or Heath upgrade cooling upgrades but undecided. I am even considering the Heaths water pump,fan,clutch combo if it would help or be the overall best choice. I will also be purchasing an ECM (Heath or Wester Still undeciede) which should help my power.
Any input is greatly appreciated.
Dieselsmoken33 thanks for starting this thread.
