I have an '05 K3500 CC LB. When the truck gets hot, it has a fairly agressive coolant leak towards the back of the driver's side of the engine. I powerwashed it and got underneath it and was able to take come pics. I believe I am seeing a crack in a metal part down there, but I don't know what the part is and what would be involved in replacing it. What is this? Is it a common problem? and what parts would I need to order to fix it? Thanks so much for your help. I am more of a 6.5 Turbo Diesel guy, but I just picked up this K3500 and am not as experienced with the Duramax trucks so I need help! The pics are from under the truck pointing up towards the driver's side, kind of near the oil filter. You can see the crack where I indicated and then you can see where the coolant runs downhill. Thanks again!![lly2.jpg lly2.jpg](https://www.thetruckstop.us/forum/data/attachments/30/30686-6a97169788ec026941457ebba9503a2d.jpg)
![LLY.jpg LLY.jpg](https://www.thetruckstop.us/forum/data/attachments/30/30685-959bee436f9096cd53f852847461b846.jpg)
