Do you recommend the Hayden brand severe duty clutch?
handcannon, Hayden's sever duty clutch is supposed to come on at 170*, you probablly got a lemon, you should of returnned for another, rather than go with heath overpriced stuff.
bk95td do you mean the backing plate, or the plate behind that?
Heath's is the Hayden SD.
Another place they can and will leak is between the aluminum timing cover and the front of the block. I've had 2 trucks do this. There is only anarobic sealer in there, no gasket from the factory. You may break that seal when you replace the water pump. It happened to me. It sucks to do it twice.
I've never come close to ever overheating since installing it, and it cycles in & out unlike the Kennedy one I ran for years that never disengaged once engaged, may have been a bad unit there so not disparaging Kennedy at all.
