Well it's comments like that are the reason I posed the question. I am not looking to make a power monster, just good dd truck that gets good milage. I really dislike gasoline due to burning the hell out of my self a year ago. Filling up used to just piss me off, now the smell makes me dry heave. I love the truck and really hoped to find an "easy" swap but it doesn't look like that's going to happen. Time to put on my big girl panties and get over the stench of gasoline.
I really wanted it to be a plug and play swap.
Oh, you can do it.
Not plug and play by any means.
It's a 4l60E from what I can find listed for a 2000 which is this body style:
4 door Yukon in a party dress and lipstick.
Mechanical 6.5 would be easier in some respects.
But your 4l60E is gonna freak out behind it. You need lots of inputs to the PCM that won't be there and you'll have to figure out a way to jack @$$ them in there. Even then, there's no way of knowing if your PCM won't just kick the whole mess into limp mode.....
Things are gonna get even weirder when you get into the AWD system.
Then there's the whole hydroboost brake system since the diesel won't make any vacuum to run your vacuum booster. I suppose you could use the vacuum pump and a reservoir to get by, but I don't think I'd trust my brakes to that.....
I'd stick with replacing the gas engine if you really like the truck because you're going to curse the life out of it if you go with a diesel swap and
IF you ever get it running again.
I like a challenge and a good running diesel as much as anyone else, but if it were me I wouldn't even attempt that with your truck.
Honestly, I'd sell it and get a newer one already with the diesel option.
I know, I know......not made of money and all that stuff......Denali's aren't cheap......
