dragonriot
6.5 Engine Diagnostic Troubleshooting Checklist
Copy and paste this checklist into a new post, then answer all the questions by typing in your data into the (red) blanks as indicated - click in the middle of the blank, start typing.
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _Began as an intermittent and sudden shut off, followed by immediate restart and no further problems. Now, when it dies, I'm lucky to be able to restart it and get myself home.___________________________
- Year: __1994____
- Truck model and class (ie: c2500) __Yukon (K5 Style)_______
- Automatic or Standard _Auto_________
- Mileage: (indicate miles or km) _220000________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) __Chip, plugs, manual wastegate controller from HeathDiesel_________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? __Turbo____________
- Ambient outside temp: (indicate *C or *F) __variable (wisconsin, lol) about 45 F now________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __#2 Diesel - up to 10% bio if I'm lucky_______
- What fuel additives are you using? __DieselPower Fuel Treatment on last tank_________
- Where are you located? __Milwaukee, WI___________
- Air filter __1000 miles ago_______
- Fuel filter __1000 miles ago_______
- CDR Valve? _unknown________
- Coolant – last flushed/replaced at __last year___________
- Oil – synthetic/regular, changed at __Rotella T 15W40, Wicks, 1000 miles ago_________
- Batteries – state of charge, (matched set) replaced at _both new about 10k miles____________
- Battery cables and grounds (removed, cleaned and tightened): __new____________
- Glow Plugs - how many miles on them? __50,000_______ What type? __the good ones...___________
- Injectors - last changed at __unknown_____________
- What were you doing when it happened? __daily driving____________
- How was the truck running fine before this problem appeared? __Truck always seems to run fine, right up to the stall___________
- Has this problem ever happened before? __hundreds of times over the past 4 months_____________________
- Describe any related factors that might be part of the problem. __PMD was relocated BACK to IP after service about 2 years ago... I was angry at the mechanic, and when asked why, they said that it doesn't matter. I have since tried to replace the FSDCooler I have for the IP mounted PMD, but the cable is too short.____________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _Yes___ And? _Code 23 and 39, cleared and driven for 10 miles... No reappearance of either code. Only getting Code 12 now._______
Diagnostics:
1] Starting:
1a] Does the engine start? __Yes_______
1b] Does the engine crank over? __Yes______
1c] Are your batteries fully charged? __Yes_______
1d] Have you removed, cleaned, and tightened all battery connections? __Yes______
1e] Does your Wait to Start light come on for a time? How long? __No, never_______
1f] Does your glow plug light come on? ___Yes______ For how long? _15-30 seconds depending on temperature________
1g] Do you see smoke from the exhaust while cranking? What color? __No, but on first start, a fair bit of white smoke is produced and goes away imediately______
1h] Does the Service Engine Light Glow during Start/bulb check? __Only while glowplugs are firing, but not during start______
2a] Can you hear your lift pump working? ___yes_________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? __yes_______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ____yes_______
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___yes________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) __on pump - sadly_________
3b] Condition of Extension harness (if used) Vendor or Homemade? ___not used______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ___looks good to me______
3d] PMD Make: __Standyne_________
3e] PMD Age: ___Original I think - have replacement already mounted on FSDCooler__________
4] Stalling Issues
4a] Do you experience stalling only when hot? ___Yes, runs fine when engine first starts. I can drive about 10 miles before it starts to die repeatedly._________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _on accel_____
4c] Does pouring cool water over the IP seem to help with restarting? __unknown_______
4d] Is stalling momentary (engine recovers)? __usually, but as of late, it takes a much longer time to recover_______
4e] Does SES light come on when engine hiccups? __no, it shows no codes and no lights_______
4f] Does cruise control quit working when engine hiccups? __N/A_________
4h] Changes to dash lights or instruments during stalling events? ___All gauges go to zero (except fuel)________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __no_____
5b] Any bubbles or oil film in coolant overflow tank? _no______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _no_________
5d] Excessive white smoke from exhaust on cold start? __I wouldn't say excessive... but there is white smoke on every cold start_______
5e] Excessive black smoke from exhaust under hard acceleration? __Only slight black smoke________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? __no_________
6b] Maximum boost under load? ___set wastegate controller to recommended 1 3/4" length, unknown boost under load_________
6c] Have you added a performance PCM (reflash) or Chip? __yes, 80hp chip about 4 years ago from HeathDiesel___________
6d] Have you changed exhaust / downpipe / crossover? ___exhaust was new when I bought the truck, 3 1/2" all the way back_____________
6e] Wastegate – mechanical or vacuum (OEM)? __mechanical (aftermarket)____________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
__Neighbor has described the sound of my truck as marbles in a coffee can... I don't hear it, I just hear diesel rumble. Truck starts fine, and drives normally for about 5-10 miles, then starts to stall in traffic under acceleration. This is a semi-new problem, and have asked the only diesel performance shop in Milwaukee to check it out, they found nothing wrong... but they also forgot to reconnect the turbo oil hose after an air filter replacement, so I don't take much stock in anything they say now. I replaced the glow plugs, chip, and wastegate controller, and a previous mechanic moved the remote mounted PMD on FSDCooler back to the pump during service a few years ago. At least I have a spare... The cable seems to be stuck and too short to reach the FSDCooler mounted PMD, or I would have already put it back on the manifold. I would gladly remote mount the thing on the bumper... if I could afford more than fuel for the damn thing right now. heh. Truck has a Winter Package, which is handy because it gets mighty cold here in about a month. I haven't checked the fuel sock in the tank, as I haven't pulled the tank down in about 2 years. All filters are 1000 miles old and lift pump is newly replaced within the last year along with brand new fuel lines from the tank to the engine._______________________________
- Year: __1994____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
