buddy
Active Member
So my only question would be is if you have them plugged in backwards? I suppose you tried switching them before though, and it doesnt look like an easy transistion back to just running one of them. If you can I would just run the stock one alone.
Although the jumpers are a little off it should only read like 5mph slow. Unless the GV unit somehow is doing something wrong because of it.
They will need a different divisor because the gear vendors essentially acts like a rear gear ratio change as it relates to the PCM/speedo. Like 2.91 vs 4.10
I suspect something wrong in the GV unit.
