pneese973
I am the new owner of the 1994 Chevy 2500 6.5L Turbo Diesel. I am very knowledgeable with diesel engines and build/work on/modify VW diesel engines on a regular basis (probably 15+/year). I've even rebuilt a few Bosche VE Rotary Pumps before. Anyway, I've done quite a few things to the truck that has been in question and have a lot of info and am confused about what's going on. A friend of mine who has owned a 1995 6.5L TD has been helping me and he's been able to keep his on the road for over 350,000 miles. Below is a list of what I know thus far and what I've done to the truck.
1) Ordered and installed a new PMD and remote installation kit. I installed the PMD behind the front bumper where it will be cool and get good airflow.
2) Since the truck is at a friends house, we hit it with a 100A charger and jumped it with another vehicle. We bled the filter and found a very small amount of air present. Filter was bled with a bottle and clear line and run the pump until we got about a quart of fuel out of it and closed the filter drain with the pump running.
3) Fuel smells stale (maybe from bacteria???). Drained tank and put 10 gallons on new fuel and fuel treatment in the tank. Took old fuel and found it hard to light when putting a torch to it. Torch took maybe 5-10 seconds before old fuel would even try to burn.
4) Removed plunger from Idle Cutoff Switch.
The truck has new glow plugs, I can hear the lift pump running, #9 resistor installed, a new PMD, and a new fuel filter. I think the PO may have changed the lift pump as well.
Here's where it's at.....
Truck will fire off ether and runs great. I tried running it until it got to about 180 degrees, shut it off, and tried to immediately start it. No luck, but will start right back if it has a very small sniff of ether.
Truck has a funny smell out of the exhaust while cranking (like stale fuel) and I saw smoke out of the exhaust while trying to start it.
Once started, truck runs great. No surging (typical of weak IP), stalling, hesitation, nothing. In 1/4 mile, it has no problem getting to 80+MPH from a dead stop. Service Engine Soon light is constantly on, but no codes (only 12) stored (found by jumping the 2 pins).
I've tried unplugging (one at a time) the coolant temp sensor, IAT sensor, and the map??? sensor and tried starting it and no luck.
All fuses are in tact. ECM was reset after new PMD installed so it wasn't running off old mapping data.
Truck has some blowby but nothing significant.
I thought (and my friend agreed) that when running it sounds like it's got a little more detention noise than it should have like it's a little advanced. It runs so good and smooth that I really don't think the IP is shot. What would a bad optical sensor do to it? I'm wondering if a bad optical sensor or crankshaft position sensor might be the problem. Any thought?
