Can you confirm that setup fits in the engine by and doesn't hit the air box? I also like the idea of a mechanical turbo master, but only visual proof I've seen of a holset working in place (not to say it doesn't exist or is possible elsewhere) is @n8in8or's CKO HX40 with the aforementioned horizontal actuator
So fuel mileage is still good with the increased fuel IP's?
Yes, i had aneroid on one of mine for the daily driving. I just controlled mine under the hood. Had 2 positions i would use labeled cop and no cop! Haha. So basically ‘set it’ through tuning it to be ok on street and never any smoke and would turn it to that. Then time to play, I popped the hood and it was like shutting it off, so it would leave a small trail, but mixed with tire smoke so no one knew it was diesel.
Yes, when you use aneroid and resist mps (mashed pedal syndrome) the mileage was good.
But if you are after amazing mpg- you need to do a tiny pump for that which barely gets the truck up to speed, have 0 boost at speed so there is no back pressure from turbo.
@Rockabillyrat So my new pump-Do I just buy and send to you direct for building or do you buy the pump and modify it and I pay you all at once?
This is the message I got from the seller about the 6 blade wheel I purchased:
I bought some of those wheels a few years ago as part of a package from a
shop that was closing. I only have a few left. The wheels are balanced. I
don't know who manufactured them because the wheels were not in original
packaging.
@Rockabillyrat what is the output of a stock 4911 IP?
