DieselAmateur
It most likely isn't genuine Holset, but for $40 I figured I can't lose. Can't justify spending $150+ for a billet wheel made in Taiwan with tooling marks/ ridges between the blades. Nitpicking and probably not noticeable in performance but I've read those ridges you see in all billet wheels increase drag and are weak spots in the material.
anywho...
Here's some pictures of the wheel compared to what came with the unit I purchased. 6 blade on the left, stock 7 on the right
Underside, note no part numbers or machining marks on the mystery 6 blade compared to the 7
Close up of part numbers/ letters/ identification on 7 blade
Wish I had taken more measurements but it does seem to fit as it should. I could email the seller and see if he has any info on the wheel's origins. If only he had a 10 blade 70/60 turbine too!
anywho...
