TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
Schiker, I agree with most of your analysis. If the idler and pitman arms are weak, then this is simply going to apply more force to them, since the force has no where else to go, i.e. the center link / drag link cannot rotate anymore, so the energy is not used for rotational (kinetic) motion - it is simply imparted as a lateral force to the tip of the pitman and idler arms. So, yes - if the idler and pitman are not really strong, you could snap the end of them off.
Hmm. It seems to me that the optimal solution would be to replace components (possibly ALL components) with heavier duty versions, and THEN apply the Cognito and Supersteer components.
I like the idea of the SuperSteer Idler Pivot, as it replaces what is essential a bushing pivot pin with a real roller and ball-bearing idler pivot. I believe that this will allow the entire steering assembly to move more freely and smoothly, with very little wear, at least on the rotating assemblies. It should tighten up the steering quite a bit.
The Cognito brackets should halt the ability of the drag link to rotate on the idler and pitman arm pins, which will stabilize the steering from having 'fluctuating' toe-in, and from wearing by virtue of that excessive rotation.
This is definitely looking expensive up-front. The braces and SuperSteer idler pivot are around $500 just for the parts, but I suppose it would halt the need to have new pitman/ilders and so-on every couple of years.
-Rob
-Rob
