Turbine Doc
Just Another Diesel Guy
Ive had a code 34 since I did my IP, I know the timing is off, its loud when its cold.. Is your timing ok?
Which one the 94 ??? if it's the 97 I'm gonna whup U as I could have set it when I was there.
If anyone was actually curious: problem fixed; WAY out of base timing. Using the mark I was told to use on the IP, base was about 15* advanced....maxed out on the IP. Reset to 10* and the light is out. Not quite as peppy and a little harder to start in the morning with more white smoke but at least it's a lot quieter and no more CEL.
