Michaeljp86
EVIL GENIUS
I still cant clear the codes, I took the battery cables off and let is sit for a while when I had lunch and it still had both codes. I tried to do the pedal thing again and it didnt work.
Are you checking codes before cranking again? Maybe your TCM is just messed up.
Just to verify, Did you check the trans fuse? A little info here on which wire does what http://www.atraonline.com/manuals/general/tetdv/tetdv-c3h.htm
