Acesneights1
What does that mean what it says ? I have never heard of the resistor going bad in these. The truck stalls . when I clear the code it comes right back and when it does the truck shudders for a sec. PMD is on the IP . IP looks to have been changed somewhere along the line. Would PMD throw that ? Also she's knocking pretty good at idle. Sounds like real bad fuel knock like when you change injectors. Des and actual timing are at 5 deg but I can't do timing on it until I take care of the code. I really don't want to throw 4-500$ at this rag for a PMD kit not knowing what else might be wrong. Might try one of those "good used" ones for now but would that 56 be for the PMD or something else ?
