RadioMan
Recruit
Not sure if the Tahoe is the same, but schematic for the 95 PU shows ESO and Fuel Solenoid on a 20A fuse. Lift pump on a totaly different circuit.
Or wiring\harness\connector - maybe the IP harness is shorting to the IP, down in and under there, where you cannot see it
