DieselSlug
Had some time to try and figure out my plow lights. The marker lights worked but the high and low beams didnt. Ended up running a ground, which the plow needed. The lights still didn't work. Checked the relays behind the drivers parking light and they were corroded badly. Luckily last time i went to the junkyard i grabbed 2 relays from a Dodge van. They happen to be the exact number and everything! Swapped one in and the low beams worked. Swapped the other and now the high beams work. So i have working plow lights again, but the headlight on the drivers side is very dim, i am thinking it needs to be replaced. I am also soaking the studs in penetrant so i can carefully loosen them without ruining the housing so i can re point the beams.
Also included a picture of my shot rotor, had metal on metal the other day.
