Hi! About a month ago my truck wouldn't start at 15° so u plugged her in. 2 hours passes, didn't start.. next day tested block heater and found it was just stop working. Replaced glowplugs all were good had 14 amps coming out wire harness. Checked plunger was good, disconnected optical senser nothing changed. Checked for fuel out front injection pump hose, it was good. I also had fuel to pump and t valve. Checked all engine eletrical, and ground straps needed some cleaning. Also checked all battery cables all fuses tested good. I replaced pmd with new one supposeddly, that came with the tuck not sure if it works, looks newish.. I know I should buy another one to check but I'm already spent 500 in witch ain't to much considering if I took to a shop! The only thing I didn't fully check was the return lines and I cracked 1 injector to bleed( fuel misted out). Also just got done replacing block heater. Service engine light is on before start, but weird thing is it flashes once after ignition switched on, then is lit constant after. What am I missing? She was just running fine!
