Charge Air Coolers
Twisted Steel Performance
Pauline, SC
It's getting hot here in the south, I'm finishing up 2 Charge Air Cooler kits for customers, these will require very little mods to install, I provide brackets for the cooler mounting and bolts, intake adapter with gasket & SS bolts, and a turbo V-band adapter that doesn't require you to grind off the flange if using a Holset type compressor cover. 001.JPG
Everything is given a Thermal Dispersant coating that prevents corrosion and provides 30% more heat transfer than bare Aluminum.
I am thinking about offering this kit but for now it's built per order...
I will post pics of the entire kit and a couple of the cooler installed later
