Charge air cooler with minimal bother
On the global warming subject, even if this winter's weather was an average of 20 degrees colder across the entire country, one year is a completely insignificant sample size - can't make any statistically/scientifically valid statement on global temp shift/difference over the time man has inhabited the earth.
The big reason I will always continue working to better understand things is because the old saying "we mock what we don't understand" is so...... completely true.
Most all of us do that. And it absolutely gets in the way of bettering our understanding. Repeatedly, I've found that, until I know a thing, I'm not in a position to adequately judge whether knowing that thing is valuable or not.
Guess if you could still find an IC in kit form for the 6.5, you could possibly say the IC is far more $$$$, than the $495 WMI kit.
In today's IC market, if you don't mind doing the work yourself, you can put together a well designed & functioning IC at equal or less cost than $495.
Not saying the WMI isn't a valid charge cooling method. But don't think the general cost comparison is skewed to either IC or WMI's cost advantage.
