I have not ridden one yet. I talked to the man on the phone and wanted to ask some one who has one. He said the rincon uses a TC instead of belts.
Thanks for the reply
No all of them use the same oil. My CRF450X, used to different oil reservoirs.i think, with any motorcycle, atv, etc, you should NEVER USE ANY SYNTHETIC OR NON MFG APPROVED OIL. The clutch runs on the same oil, if you use a different oil than what specified to be used, the clutch will have problems and will eventually fail.
My $.02, you arent using this thing to ride 50,000 Mi a year, so just put normal Honda oil in there...
I am pretty sure, that is no correct.I would of atleast waited til the warranty was out, they can void it for not running Honda oil.
Try out a Rubicon. The engine/transmission braking is UNREAL........esp. if in LOW 4X4. I only have to use brakes on EXTREME angles.Nick, does your Rincon have compression braking? I'm about to pull the trigger and get a new 4-wheeler. I was thinking of a Rincon but the Honda man said it uses a torque converter and has no engine braking. I need engine braking as the mountains where we hunt are very steep.
I then thought about the Rancher 420 AT 4X4. It's also less expensive.
You CAN use the same oil, which I do. But, you can use different oils, since they are separated.Hmm, i have an X, and i think it runs on one oil. But im not sure. :sosp:
