Husker6.5
I was a Maintenance Technician in a certified organic cereal plant here in Lincoln. Since it was food processing, everything was stainless steel. Got pretty good at gas shielded MIG welding. TIG, eh, so-so, my hands just aren't steady enough anymore. Just have here at home a cheap 95 Amp wire-feed welder running .035 flux core that handles just about anything pretty well, including welding the two halves of my old 72 Dodge pickup frame back together after I cut it just in front of the box, flipped the next section up to the transmission crossmember over, and rewelded it to then weld an A frame on with a coupler so that the box would sit level when I had it hitched to the back of my Suburban. The welder does have the capability to convert to gas shielded if I wanted to buy a roll of stainless steel wire ($$$) and a bottle of Argon/CO2 and tinker with, say, welding up a set of stainless steel 6.5 headers (not! or at least not at this time!).
