6.5L
Old Iron Runner
So I know from the factory the CDR routes back into the intake. Do you have to route it back into the intake pre-turbo or can you just vent to atmosphere? Any cons to venting to atmosphere?
I have often wondered about the CDR valve. One day i was doing a service on my truck. I pulled out the air filter to change it. Well the phone rang, a friend stopped by then the phone again. To make a long story short i slammed the hood and forgot to install the air filter. Ran into town and back and ever since that day the rear main has leaked a ton of oil. Air filter was horribly dirty and it ran great w/o the filter installed. My guess to why the leak started is the CDR allowed my engine to over pressurize due to a lack of air restriction, higher turbo pressure and then blow the rear main.
My truck has a rope seal rear main its a 6.2L with 6.5L DS4 pump and turbo.
I know for emissions reasons its probably best that the oil vapors get burned, but some engines like Cummins and Duramaxes vent out the atmosphere. So it probably doesn't matter too much.
I'm not talking about the intake. right now, intake is out of the question. I want to confirm that I can to vent to atmosphere for a while until I can get some shit worked out without screwing anything up at all?
CDR Crankcase Depression Regulator
Olddieselguy : good diagnosis.
6.5: there are some lengthy threads here if you do a search about it. A worth while read to learn how to clean and test.
As long as your seals are good and you don't have a lot of blowby the best thing is to keep it stock. Once blowby is bad enough to cause you to burn a lot of oil you might consider venting to atmosphere (oil seals will usually leak by then anyways) if legal in your area, or add a catch can (cant remember proper term) to return the oil to the pan instead of burning it.
:dr: Say what? The CDR puts a vacuum on the crankcase. So replacing a clogged air filter would reduce the constant vacuum on the crankcase. This elimination of crankcase vacuum will allow bad seals to leak more. The CDR is on the vacuum side of the turbo! It isn't pressurizing the crankcase from the turbo. A quick look at the plumbing going before the turbo should confirm this. if the crankcase is seeing turbo boost something is very wrong with the setup.
I have seen a rear main seal quit leaking on a 200K mile 4.3L gas engine after unclogging the PCV system in/under the TBI.
As far as venting a CDR to the road it is only a bad idea on high blow by engines that can fog an intersection. It really doesn't hurt anything to keep it in the intake on a non-EGR engine.
All this venting going on, thought I'd share my vent. ($.02)
Keep the oil, lose the pressure is the goal. If one could improve the oil control, the OE setup isn't all bad.
A little vacuum on the crankcase won't hurt a thing. One could argue that it keep oil leaks away- but so does Ultra Black RTV.
What you DO NOT want is any kind of pressure in the crankcase. Pressure = leaks for sure. (and usually more blowby due to the unseating of the rings)
A free flowing vent that keeps your oil where it should be will suffice.
Personally, I do not want my engine breathing it's own trash.
View attachment 38845View attachment 38846View attachment 38847View attachment 38848View attachment 38849View attachment 38850
and you never did a write up on this because you thought no one would be interested?? lol
X3, yea thats dead sexy! tell us more.
