Acesneights1
F'in Mice. That was why I pulled mine in the first place. Yep, mine was a Harrison too.
Well, tow major cold snowstorms later and I can plow in 0 deg weather with wind with the heat on low and the window open. I am seriuos the heater will blow you out of the cab.
Mines not that great, but the air is certainly hot. I think it's because there is so much un-insulated space in my blazer that the heat never really fills the cab. It works great when i switch if from "heat" to "vent" every so often to spread the heat around.
Flexolite makes a rear heater for about 200$. it is exactly the same one the burbs of that era came factory with. Course if you can find a functional one from an old burb, that would work too. I plan on buying the flexolite one for my Burb. Same problem.
