Husker6.5
Gear Vendor unit not really an option on the K2500. I'd have six grand into it after divorcing the transfer case from the transmission, putting the GV in between, and then making all new front and rear drive shafts to maintain 4WD, or else mount it behind the transfer case and use it only in 2WD and still have to make a new drive shaft for the rear. 3.42's in the front and rear diffs would only help a little bit from my 3.73's, I don't want to go to 33" or 35" tires and a lift because of the air resistance factor. 3.42's with an ~ 0.62 OD would be ideal RPMs at 75-80MPH. If they made a 3.21 ring and pinion for the front 9.25" IFS diff like they do for the 10.5" 14 bolt rear diff, problem solved using the 4L80E, but they don't. ZF6 may be the route to go. A stick shift 'Burb would be cool.
