JiFaire
Land Mine Finder
More valves per cylinder. A serious re-think would take head re-design into account ... If you've working with a high-compression, low-clearance head, worrying about scavenging, backpressure, and TDC vacuum, it seems intuitive that head re-configuration (including perhaps a piezo-elec TDC relief) would be in order.
Superficial modifications will likely run into the same design barriers that have haunted us in the past... there is only so much extra you can get from a closed design. If you're gonna think outside the box, start outside the box.
