Acesneights1
Pulled the Camper out to start cleaning it up and at first glance the tires looked fine but closer inspection revealed cracking and dry rot. These could very well be original 10 yr old tires and they were Load Range B to begin with. The new ones I got are Load Range D but my dilema is the Rims are stamped 50psi max and the Range D tires run 65psi at max weight. I am wondering should I run them at 50 psi or 65 psi. Gonna call tire supplier tommorow and see what they say. Just remember that a blow out on these campers can do serious damage to the camper aside from causing an accident.
