Just starting to notice a rattle when hitting bumps,more rapid of a rattle over stutter type bumps,less over normal road imperfections. I have looked and touched anything and everything that could be loose and have found nothing! Steering shaft is the upgraded one and is tight, all body mounts,and hardware is tight. I can grab the caliper and move it, yes I know there is suppose to be some give,but could there be enough to cause the calipers to rattle around when driving?? I'm running 70 psi all the way round cause I am hauling wood and usually run 60 psi the rest of the time. Any thing else I should check?? My psi choices OK ??
