busdriver75
Busier than hell...
A couple of beers and I had nerves of steel.:sifone:
as long as the measurements were made pre-beers!!!:cheers2:
About how long does it take for the install?
Some shop told me like 5 hours or so. I didnt think it took that long...
Took me about an hour and a half.:thumbsup:
The new style Will NOT cover the all of the old holes. Sorry bro, i wanted to do the same. But Pacer is selling some sweet LED smoked lights for us!
And a beer after every hole.:cheers2:x2 and most of that time was double and triple checking the alignment
Do you have to pull the headliner down?
Just a little, not out completely
Like Joe said...you only have to pull the front down a little to be able to install the harness..it is so easy......a caveman could do it..Joe did it.:ciappa::smilielol5:
JoeLike Joe said...you only have to pull the front down a little to be able to install the harness..it is so easy......a caveman could do it..Joe did it.:ciappa::smilielol5:
you guys made your own harnesses right?? also, how did you guys attach them. when i put lights on the s10 i had to drill atleast 10, 1/2" holes in the cab for their stupid clips. i'd much rather find some sheet metal screws and just use a couple screws per light instead.
I've been wanting to do this for a while, just can't bring myself to pop holes in the roof of my rig! I guess the beer solution is one way to do it. Can you order the harness or do you have to make it? I'd be going with the factory ones, I assume they don't come with one...
