Big T
Big T, I've got my complete stock exhaust, still in good shape, I think (been setting outside), from when I put the DE system in. If nobody else closer to you comes up with what you need I'm offering the use of any part of my system you may need. I'm thinking the down pipe on back to just behind the cat. I did make one cut in the pipe to make it easier to remove the system, but don't remember where just now. It's pitch black outside, and raining (finally, but that's another story), but if you are interested I'll go check it out in the daylight.
It's yours to use to help you pass the inspection. All you need to do is pay shipping.
Don
I need a permanent solution, at least every two years for the smog check. Something that can be swapped in for the test/inspection and swapped back out for the DE the rest of the time. So, do you want to "lend" or "sell"? If sell, then I'd be interested in just the cat as I don't want to pay to ship pipe. If so, I need to know quickly as my wife is up in the Redding area today and I could redirect her further north to pick it up, though Albany is up there by Corvalis.
