JayTheCPA
I checked it this AM and it says Catalyst.
Allrightie then . . . Will take my lumps . . .
What size? 3 or 4"?
You just need the joint or ??
Sounds like the "intermediate" pipe with the ball and socket connection
Looks like you can use or modify part # 323001 as shown here http://www.diamondeyeperformance.com/images/sheets/K4108A.pdf
Alright, had my appointment with the smog referee. They spent more than an hour trying to calibrate their dyno and never got there. In addition, he said he couldn't pass me unless I returned the section of the exhaust from the downpipe to the cat back to stock sized. He gave me a diagram of the exhaust. So as suspected, I need another stock cat and I'll need the bubble compression flange that mates up to the Diamondeye downpipe. Then I have to get 3" pipe welded and bent to fit in there with the cat in front of the muffler.
The sole remaining test is the smoke test and it cannot linger (coming out the exhaust) more than 3 seconds after he snaps it up to 3000 rpm. It will pass that as it only has a puff before the turbo spools up. On that note, the GM 5 turbo hits 15 psi with this Heath tune and it whines something awful. I don't care as it's temporary just to get it passed.
Good news is that it passed the rest of the visual inspection, including the PCV lines :hihi:
Leroy, will need your help sourcing said bubble flange to connect to the DE downpipe. That or I have to get a stock downpipe. Paul is working on getting me a cat from a wrecked 3500 up near him.
Just heard back. Must buy whole section of pipe at $95 shipped.
Try this link maybe something you can use http://www.ebay.com/sch/i.html?_trk...ll+and+socket+exhaust+pipe&_sacat=0&_from=R40
