then we could split the proceeds and blow it at Leroydiesel.com.
Best idea I've heard all day:thumbsup::hihi:
the vac pumps look identical, but IIRC the 94 and 95 are threaded, and the 96+ are drilled out for straight through bolts. something like that, as I couldn't use my 1997-early 99 engine's vac pump in my 95. IDK, but am pretty certain that the 95 and older bracket wont work.
any junkyards around to get stuff? If you are short, I may be able to come up with a pump and bracket from a 96+ I'd let you borrow. we could insure the shit out of it and hope USPS looses it on the way back to me, and then we could split the proceeds and blow it at Leroydiesel.com.
I would do a little more research and see if it negatively impacts you if you test at a different location? have you been using the same spot for years, or just whoever offers smog check services? I would say a fresh air filter and fuel filter, some power service silver bottle, and a quick trip around town to warm it up fully would go a long ways to get it to pass.
good luck!
CAT CONVERTERS started on the 6.5 in 94 when the DS4 injection pump came out, and to my knowledge ALL 6.5's with DS4 pumps had a cat converter on them. The federal emission LB7 DURAMAX is the only DURAMAX that didn't have a cat converter on it either, so for the most part GM diesels from 94+ had them except for federal trucks from 01-early 04.
Also, sprung a coolant leak at one of the plastic Ts above the passenger side valve cover. It was like a solid stream of piss after I shut down Saturday, too hot to work on. It was coming straight off the clamp on the line intersecting the upper of two lines going from front yo back.
Those tee's are plastic and will fail sooner or later after prolong exposure to heat.
Mine crumpled when I tried to work on something else.
Not too difficult to replace, except they have 2 different hose sizes: 5/8" and 3/4".
In my case, in emergency a while, I used 3/4" tee and shove the 5/8" hose into 3/4" tee.
Toward the cat, still stand by that the L65's do not call for cat's, but in stating that, I went back and re-researched and found a lot of commentary regarding soot traps as OE on the L65 and not helping is that I cannot find details which explain the difference nor my notes about just the 97 & 98's . . . To add to the mix, CARB could have called for a cat, but did not find any specific information on that search either. One thing that is clear in terms of a cat on the 6.5, is that there is plenty of thoughts about what it does, does not do, and what the actual requirements are :crazy: . Even commentary here on TTS was used as sources of information in terms of the L65 calling for a soot trap, but not the cat. Not looking to stir the pot, just summing-up what information is out there . . .
That aint bad at all to me. You should have seen my DURAMAX running a PPE level 6, now that was SMOKY! I could black out the roadway behind me during the daytime.Here's a thread with two video clips showing what my Burb is capable of in terms of smoke at an elevation of 6,750':
http://www.thetruckstop.us/forum/showthread.php?35379-ATT-Rolling-Coal-at-6-750
I've got an old EGR valve you can just bolt to the top of intake manifold and connect the line too. They aren't going to pull it off and see if you've got the right intake manifold!
X2 on making the vacuum line look and seem functional.
Better question is how to address the smoke if a warmer engine does not 'fix' it . . .
Rather than fly blind into the next inspection, do you have any mechanic buddies (or friends of friends) that can offer pointers, and (even better yet) a pre-inspection for getting past all this?
Paul, you're right. He just wants to see it connected to something. The rest of the engine compartment he's scratching his head. Can you imagine if I had the ATT with Banks Sidewinder and Leroy Spooler? If that spooler is vacuum actuated, I might have my future solution for attaching the vac line.:rof:
I'll PM you my address.
