hookedup50
Leroy that does look like a good start for a project. I've wanted a CJ8 since they were new. You guys that don't live in the rust belt are lucky, as you get better starts on projects.
On the van turbo (same as hummer turbo):
It's a center mount c6. It mounts where the fuel filter mounts on a normal truck. The intake manifold bolt holes in the head are a different angle, so you need van heads,intake, up pipes, turbo. And then you have to drill the block for oil supply and return for the turbo. Complete tear down for that. I kept the truck (also n/a) heads and custom made intake mounting studs by bending gr.11 threaded rod, high heat treating, then cryogenic treating them. Then replace the intake gasket 3 times just learning to not tear it by how it puts a side load on it instead of even direct pressure.
It can be done. If you have any other options, choose plan b. Remote mount your truck turbo, it will be far less work and then you can add a qsv, or upgrade the whole turbo once you realize how many better turbo choices there are out there. Maybe put the turbo in that spot, and custom build your own headers/ up pipe to feed it as a center mount. Otherwise where ever you can fit it.
What is your upper end rpm going to be, under 2200 I hope wih any gm turbo. They will go above it, they just don't like it.
Our old 6.2 when it popped a belt it took the other one with it. Happened rather frequently compared to the serp set up.
Sent from my Studio 5.0s using Tapatalk
LeroyDiesel sells banks manifolds that mount the turbo forward by the accessories
source unknown
Welcome.
I saw a Jeep on CL today with a 6.5 the guy was selling all but the 6.5
Looked like a good start for someone.
http://houston.craigslist.org/cto/4401426211.html
WARNING! I'm in a wacky mood so...
Move the radiator to the back like your saying. Regular electric fans might not be enough though, maybe run the dmax fan off a 1 horse dc motor and twin alternators.
Custom headers going down and to the front of the engine. Come up and mount an ATT turbo in front center where the fan was. Back up top through cut outs in the hood and 1 or 2 stacks straight up. Or even back down the traditional direction if your not a stack guy.
With the ATT you are moving more air volume at lower pressure so there is no need for an IC because the air is not compressing as hard and does not heat up as much as the factory one. (That's for real, not in my crazy scheme idea). Loosing the under sized gm turbo is always a good idea.
Now I have to work on this 50 cal. turret Hayabusa side car mount idea...
