huntingman2706217
So im currently finishing up my cage and 06 SD axles with 40's under my MJ (comanche to those none jeepers). Next winter im planning for a 6.2 or 6.5 swap. I currently have the front half of a XJ (same front half a MJ has) sitting under my shed for engine mach up...
I guess ill go over what im looking for first... Im looking mainly for low end torque and reliability. I only want power gains where reliability is not reduced. and i dont care about fuel mileage. I would really like to not do any machine work since i cant do any of that myself. In a sense im looking to refresh a motor with all new gaskets and mix and match better parts... if this is even possible... lol...
So far (correct me if im on the wrong track please!!) with my research (which i feel is minimum at this point and has mainly been based on getting my tranny behind it and fitting it into the jeep) i think im going to go with a late 80's early 90's 599 block 6.2 and 6.2 heads (possibly 6.5) with 6.5 precups. I understand the 6.5's are the same block in the early years but the heads seem to have issues from what i read. ARP head studs and Scat crank are apparently a must. Delta apparently makes a cam that will help with more low end torque so i will most likely look into this however this may be something i would do down the road depending on price. Ive read you can bore the motor .30 but im not interested in doing so unless i have to. The Blocks crack enough that i dont want anything any thinner then it already is... im hoping i dont even have to pull pistons at all...
I of course would like to run a turbo however im not sure if a 6.2 specific aftermarket kit would be best (once owned a 6.2 blazer with a sidewinder kit) or if its possible to use 6.5 intake manifold with 6.2 heads and run the OEM 6.5 setup with 6.5 mechanical pump/lines and 6.5 marine injectors for the extra fuel... (again correct me if you see something wrong please!!) I also dont know which system would give the most room between the block and the frame.... people are installing Lq4's (chevys 6.0's) in XJ's with shortys and no real problems... fabrication is not a problem for me either... notching a frame is nothing...
I have a JY near me with several 6.2's and a couple 6.5's... i can get any of them for about $300... running 6.2's for $400-$500 nothing ever comes up on my CL for cheaper if anything pops up at all... I took pictures of a couple of them to see if anything looks like something i should buy for parts or something. One of which is a Jasper rebuild... Not to excited since i have seen people complain about theirs as well on various forums.
Heres a couple of my jeep build this is going on...
These are a couple pics of the 6.5's i have in my local yard... the one with the cover is a 96 truck with a jasper engine. No idea of the codes as i cant see them without taking it apart... turbo and some small stuff are gone but its pretty much complete... left out to the elements though... though all are...
next one is a 94 6.5... most of it is gone and i can probly get it even cheaper but its going to be the same block as the 6.2's and with 6.5 heads (heads are not worth a dang correct?) it actually has a bellhousing bolted on it (NV4500 possibly) which would have been nice to have... but no transmission... weird...
The 6.2's range in many years and they have two that will run... one im pretty sure is from a 82 suburban... it may have been 84 but its possible its a red block... i dont think i really care though id rather have the 599 block...
So am i on the right track? anything you would do that is a definite DUH? Any thoughts as to which engine or engines i should pick up? maybe a 6.2 then the 94's heads and the 96's intake and accessories?
Thanks for any input and help!
