ak diesel driver
6.5 driver
Before you unbolt the tranny all the way pull the horizontal bolts that connect the 2 halves of the motor mount. Then jack engine up enough to get at the bolts that hold it to the engine and frame. Won't be easy but should be doable. should be 3 bolts on the engine side and IIRC 2 on the frame side. Sometimes it's easier to do it than explain it.
