OregonHorseTug
a little heat theory..
..look out...
Just started reading this thread. I think I'm going this route after the ATT install in order to just take the edge off the IAT when I'm pulling the trailer.
Warning. Engineer/licensed gadget nut is on line. :conehead: This might make your head hurt but give it a try.
I deal a lot with things called desuperheaters on industrial steam piping. They are basically the same idea as what you're trying to do. They spray water into a steam line that is running a few hundred degrees of superheat in order to get the steam temperature down to saturation before you use it. Enough of that, now how it might apply to our engines.
You want to spray just enough water to lower the temperature to where you want it. That amount of water (cooling) is based on the mass flow of compressed air coming out of the turbo and the temperature of that flow. This is going to tell you how much water or water+methanol it will take to drop the temperature back to where you want it. The cooling comes from evaporating water or water+methanol. If the water isn't evaporated by the time it gets to your cylinder you are pumping more water than will do you any good.
You will want your spray nozzle as far upstream as you can possibly get it. If I was willing to cut into my turbo's compressor scroll it would be a nozzle running in just as the turbo scroll straightened out pointing down stream. You've only got about two and a half feet of intake tract to evaporate that spray water to get the cooling, but we're only talking about 20-50 degrees.
So, to run through it-
Mass flow of the intake air at 150 degrees target temp and what, 15 psi boost? I'll use two atmospheres or 14.7 psi to keep the calcs simple. Heat load of dropping that mass of air from say 200 degrees. (Need the heat capacity of air.) Convert that to BTUs per second and that gives you how much mass of water per second it will take to drop the temp 50 degrees at 1 BTU per pound per degree F. Again, can we do that in 3 feet at 2500 rpm?
:sleep:
  ...   yeah, yeah...
As I type this I haven't run the numbers ( I don't have my tables at home) so I don't yet know how this will work out and it might take a couple of days to get it all done. If y'all will be so good as to not let my work get in the way of furthering the knowledge base of DTR (keep reminding me) I'll have this calculation done Monday evening.
(..which reminds me, I owe TD a schematic on glow plug RTDs for measuring cylinder balance...
Mike
			..look out...
:sleep:
Mike
