slowbutsteady
I finished replacing the IP however when I was under the vehicle I saw the bolts were sheared off on the motor mount on the ddrivers side. The bolts sheared off in the block.
I'd really appreciate anyone's input as to the best way to remove the bolts after I jack up and remove the old mount.
Are the bolts soft enough that I could drill them and use an Easyout (I've never used on before and want to make sure I don't make a bigger mess. ).
