jrsavoie
Recruit
Did you try putting a line on the front of the installed lift pump to run to your containers?
I've used a higher volume fuel pump with a hose running to the suction line to suck the tank dry also.
I used line large enough to fit over the hex parts of the lift pump with a fairly thick wall and clamprd it on. It fit fairly tight and had no leaks
