saratoga
Unpaid Help
Thinking about doing a brake upgrade to the car... come to find out it has the same 312mm rotors as a Boxter and all it takes is a set of brackets, calipers and ss lines to upgrade from the single piston factory calipers to a set of 4 piston fixed mono block calipers off of a 99-up 2.7L Boxter. Everything will fit inside the factory 17" wheels without any spacers also.
The brackets and lines are $279 and the calipers can be found for $150 each on fleabay. That plus a set of pads for seriously improved stopping power for around $600 is a good deal IMO. The brakes are stiff, but there's no progressive feel to them which everyone says this upgrade dramatically improves.
