Blowed timing chain cause IP not to work
davideger514
Hey everyone having trouble my other motor blew timing chain wich then it broke crank and took some of the block with it. Bought a used motor with low miles. Used my injection pump cause the one I got with it was just filthy inside. Systems bled but I have no fuel in injection lines. Fuel shutoff solenoid works on pump. Wait to start and lift pump only stay on for a 1/2 second before shutting off also. Could the pump be shot from the other motor blowing up???? Thanks any advice would help grounds are all good
Yuppers.
The EPA set obd2 requirements that the computer could see both demanded and delivered fuel. The db2 could not do that. So GM had Stanandyne build the ds4. GM was worried about not meeting the 1996 requirements thats why they kicked it off so early.
Saddest part is the db2 beat the ds4 In each category. More efficient so better power and mpg. Then it can burn cleaner too boot. Reliability of db2 is through the roof.
Yuppers.
Thanks for the information fella , makes sense cause that 93 ran circles around this 96.
