Matt Bachand
Depends on the 6.5
I have to find out about the block heater. yours was silent at first then it started working all on it's own Matt? Hmmmm....i wonder if i just need to use it a bit? The upper radiator hose is slightly warm(but it's barely noticeable), but when i compare it to the pickups radiator hose after both being plugged in all night, the pickup's is much warmer than the blazers.
:grumble:rrr:
Like was mentioned there are different wattages so can't really compare the 2 unless the same.
Mine ALWAYS worked. Just now I seem to hear it. It has always worked each and every time I hooked it up.
FWIW, when I bought the truck, the cord was neatly wrapped up with a ziptie in a fashon of new status.
I'm not sure if it was replaced before I bought it or if someone just ran the cord under hood to use, or if it was just never used before I bought it. No idea.
But audible or not, it has always worked.
