Big T
Where does the stock 6.5 heater element plug into the block?
That's my plan, replace the one that's on the drivers side and install another one on the passenger. unless I find a dependable circulation type for less $$. also been looking at having a battery tinder wired in too so that it keeps the batteries up in freezing weather.Get a circulating heater, they can go in one of the heater core hoses, they aren't that much and will heat the whole block.
When I rebuilt my engines, I Put a regular block heater on each side. That way the whole block is heated.
Yep. I need to plug her truck in. I installed an outside outlet to plug the vehicles into. Right now, the snow is about waist deep for about 20 foot to get to it, to plug stuff in.Guess I put on my jacket and go out and see if that block heater is making noise.![]()
I would look into a Webasto or something similat before that. I just sold a Webasto that never got installed, last Fall or summer.I was figuring on staying with the 600 watt and using one on each side of the block since it really doesn't get that cold here in south Texas but only about a month out of the year. the battery tinder would only be maybe a 2 or 4 amp charger unless I go with something that has the capability of pushing 10 amps and be automatic.
for the idea I had with camping and fishing. I had the thought of using an old style computer UPS battery backup where it's batteries would be the truck batteries. when plugged in it would charge the truck and also have a built in inverter I could turn on or off for things one might use on a camping trip. those normally have a 400 watt inverter built in and if I were to park overnight in a park or some fishing piers, they have power available. for me that would be a micro rv setup
the inverter side would only be active if I needed to use it on the road or have something powered while driving, but when plugged in, it would be a simple surge power strip for something like a coffee pot lol
are those the mini diesel hot air heaters? I am wanting to try one out. have seen them on amazon and ebay for a decent price. perfect for the no power situation in the house or for campingI would look into a Webasto or something similat before that. I just sold a Webasto that never got installed, last Fall or summer.
Diesel block heater. You can get a remote start for them.are those the mini diesel hot air heaters? I am wanting to try one out. have seen them on amazon and ebay for a decent price. perfect for the no power situation in the house or for camping![]()
WOW I just looked up on google what that was! diesel powered block heater that would also provide hot water and heat for a fan radiator heater on boats! this would be an awesome thing on an rv for it being close to self sufficient off grid! I would expect it to come with a hefty price tag though.Diesel block heater. You can get a remote start for them.
I had webasto tsl17
Webasto heaters are huge in the overland community more for interior heating via use of diesel or gasoline for RTT's and slide ins.WOW I just looked up on google what that was! diesel powered block heater that would also provide hot water and heat for a fan radiator heater on boats! this would be an awesome thing on an rv for it being close to self sufficient off grid! I would expect it to come with a hefty price tag though.
Price wasn't terrible.WOW I just looked up on google what that was! diesel powered block heater that would also provide hot water and heat for a fan radiator heater on boats! this would be an awesome thing on an rv for it being close to self sufficient off grid! I would expect it to come with a hefty price tag though.
All my outside GFI recepticles are on dedicated breakers, I could turn them on or off with the breaker. Sometimes I do but usually use a timer.Yep. I need to plug her truck in. I installed an outside outlet to plug the vehicles into. Right now, the snow is about waist deep for about 20 foot to get to it, to plug stuff in.
We have a cord plugged into the Jeep, but didn't plug it into the outlet, because we weren't going to use it for a day or 2.
Now I'm wishing I had run the outlet through a switch so we could plug everything in and turn it on and off from inside the house.
My daughter's outside recepticles are on a switch in her closet. Right next to the closet light switch. Her outside recepticles would work sometimes and sometimes not. I happened to be over on a day when they quit working. It took me about 45 minutes to find the switch in her closet.
Ours is on a dedicated breaker but you have to go outside and around the house to get in the basement, to get to the breaker box. Not so handy.All my outside GFI recepticles are on dedicated breakers, I could turn them on or off with the breaker. Sometimes I do but usually use a timer.
I hate smart anything. LOL. I have trouble even answering my flancy new smart phone. I'm missing my old flipperThere is those smart controllers. Plug it in then plug in whatever you want to it. Then smart phone activates it. Basically it is a remote control relay. I hate ‘smart’ stuff but that is a cool option.
