Yep, I'm with you on dual gen/alt being perhaps the best option, running together the demand would be split between them, running isolated also has it pro's tooMaybe should have started with audio as a goal. Big caps help the sudden draw for a good low punch.
So 1000w RMS is like 60amps aka ask the alt to power the glow plugs. Peak and efficieny figure to ballpark 60A. Two of them to need 120A at idle plus all other loads.
IMO an alternator upgrade (dual alt? ) as well as a charge wire upgrade replacement is in order just to keep up.
Engine off amp use???
Your stock alternator is 145 amps. If you do dual alternators correctly, there is nothing wrong with them. GM didn't just hook them up independantly, but instead used the ecm to control each one independantly. That said, 200 amp versions of your stock alternator are all over, I believe GM even offerred one. If it was mine, I would upgrade the charge wire at the alternator and install a fuse in it instead of the stock fusible link, connect your amp power supply to the junction block, ground to the block, and go with the factory dual alternator setup. I like power caps myself as it will definately ease the peak draw and even it out. For 1200 watts that is roughly 100 amps of current draw, so no small load, but not huge either. With the dual alternators I believe GM rates the junction block to supply that much power for upfitter useage, so why not give it a shot before you go cutting up the factory harness's to change battery cables.
Power draw at idle should be under 20 amps for an lbz. The lbz came stock with essentially an ad244(call it an ar44 or something, but it's just a next gen ad244), so idle output will be 90-100 amps, put 2 on it and he's got more than enough. You can also get the high output alternator pulleys which are a good bit smaller and increase alternator speed for increased idle output.Idle output of the stock alt wouldn't be enough. I recall the Dmax injectors and trans computer are power hogs. Engine off use should have deep cycle battries. Charging them via the engine - again bigger alt. AGM can take all it can put out during bulk charging. I have seen 50A limited only by small long run of wire from my 60A converter into Lifeline AGM batteries. Yeah, genset has to open it up to power that.
