SS FORCE
Active Member
Hello all,
I am currently working on doing the big 3 upgrade on my 06 LBZ.
I bought Knukonceptz kolossus flex 1/0 OFC, ring terminals, wire loom and a fuse for the alt portion to complete the task. In looking at the stock wiring setup though I think I'll end up rewiring all the battery connections. Currently the alt wire goes to the distribution block on the side of the engine block. I have read to leave this one in place and run the additional 1/0 wire to the + side battery. Can I just get rid of this connection entirely during my rewire and run 2 cables, one to the + of each battery? Or do I only need to do one? Is there any reason to leave the stock alt cable in place?
I don't like how the wiring between the batteries was run on these trucks. Seems they had it setup much simpler on my old 97 6.5TD. The 06 has wires running from one battery to the other by way of going under the front of the engine.
Anyone on here done this and have any feedback on a better way? Do I leave the distribution block and just add the second + alt charge wire?
