SnowDrift
Ultra Conservative. ULTRA!
Can the heads still be removed without pulling the engine with studs, or does that go away once studs are used?
Yes they can, but you have to remove the studs. The ARP studs have an small female Allen head on the end of them for removal, but if you were to use red locktite, you would end up rounding the allen head out before they would come out.Can the heads still be removed without pulling the engine with studs, or does that go away once studs are used?
