Ed HD
Formerly: Dad's 05 LLY
Yep, Bilstein is a German company. Just like Bosch, etc.
Don't misunderstand ... Nick just decided he wasn't getting enough business here and that's probably because his prices weren't any better than others. Nothing wrong with him. His tech knowledge is well respected. We don't have a suspension vendor so go with whoever you like. If it were me, I'd google search around and see what comes up. If TD checks in it would help. He's got pretty good rear suspension savy.
PreciselyYeah, a little squish is needed. I usually run 'em down until the bushing expands to the same diameter (or very close) as the concave specialty washers includud. Sway bar end links like this method too.
For the eye ends, the inner sleeve needs to be locked down to the vehicle bracket as one piece. If not the bolt will wear into your brackets and will rattle the entire time doing so.
IMO..
concave looking from the top, btw.
ok, got the bottom correct, will need to change the upper washer around. I tightened till they were nearly the same diameter, all seems well so far.
