best place to buy solenoid A and B
mig. drilled a hole, same as the bolt, welded a nut to the outside and a washer to the inside. had the heat too high the first time because the last thing i welded was the drive shaft. turned it down, slowed the speed and it worked good. had to do some hole filling though.
been running with the manual control on the 4L80 but the TCC solenoid stopped working, at least that's what i'm thinking right now. drain plug will come in handy earlier than i thought. going to drop the pan tomorrow.
now it's time for me to feel like an idiot!
pulled the pan to get to work. 1st thing i saw was this:
this is before i touched anything. guess i will be working by looking for the cause now instead of replacing.
fluid looked great so i will be reusing that. the drain plug BTW made it so all i got on my hand was 2-3 drops. love it.
Hard to tell from the angle but did the wires get pinched between the case and the pan?
